Rain Leak in my 240
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
LaRy
Post by LaRy »
A friend of mine described a similar problem with a 240 from 1986. He found out that he had fatige cracks around one of the the door hinges. So when he welded that crack, the water stopped coming in.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Several years ago I had a similar problem on a 240 and a dealer told me how to fix it.
The rain water from around the windscreen area drains off between the outer and inner wings. It does not have any conduits so pours down unhindered.
Inside the car in front of the front door pillars you will see two card trims. Take them out - it is quite easy - and check behind them for any places where the waterproof membrane is not fastened down or is holed. If in doubt fasten it all down with duct tape.
To test if this is the problem area use a hose pipe to pour lots of water over the windscreen whilst the trim cards are out.
Hope this helps.
Bill.
hjc212
Post by hjc212 »
Bill,
I have the same problem described in the original question. During really hard rains on the drivers side (91 240 wagon) I get a small puddle of water. Fortunately the rubber mats catch it. It pools up just to the left of the brake pedal.
I looked at my car after reading your fix and could not figure out which piece you are talking about. Any way you could post a digital picture?
thanks - Buck
