2004 s80 t6 leaking coolant under car
Donte25_williams
- Year and Model: 2004 Volvo S80 t6
I saw coolant on the ground today and when I looked under the car it was leaking on the passenger side near the compressor area but seem to be comin from a little higher up I really couldn't see that good but prior to driving it wasn't overheating or anything it happened when I got out and turned the car off for about 10 mins but after I saw the leak I got in the car started it and the message show "low coolant stop engine" but my temperature gauge was still in the middle idk where the leak it ...PLEASE HELP
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
It could be the coolant reservoir and/or its cap. Of course, check the hoses. If you're unlucky, it's the plastic nipple on the thermostat housing that has become brittle and leaking; this is a bear to get to and replace, so let's hope it is something simpler. Good luck and keep us posted.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
DO NOT drive it until repair is made. As previous responder said, could be the nipple, repair is in the database, look in XC90 T-6 section. Let us know what you find
Current Volvos:
Donte25_williams
Thanks for the reply I took it to a Volvo specialist they said it was a crack in the intake manifold and it's costing a grip to repair
- 979 Views
Last post by fixer333
- 1662 Views
Last post by jonesg
- 2179 Views
Last post by Reys
- 1298 Views
Last post by 800artfreed
- 604 Views
Last post by jonesg
