'99 S70 -- CEL and 3 Codes; P01017; P01081 and P0562
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Engine fan running on after shut off. Temp. gauge in normal range. Engine running rough, CEL and codes 1017, 1081 and 562. Any ideas? Car sat for a while while working on suspension and some other stuff and I had it out on the highway for two separate 30 mile test rides. CEL was after the second ride. First ride was smooth as silk. P.S. switch immobilizer ring out with junkyard unit recently. Battery rand down while sitting and I had to charge it. Tested at Autozone tonight and came up a little low, but no bad cells. Alternator and starter tested fine.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
Sommerfeldt
- Year and Model: 2018 S90 T8
- Has thanked: 55 times
- Been thanked: 42 times
I'm putting 5 bucks on the IAC, though the immobilizer code is strange. The 562 shouldn't come back if your voltage is up to par...
- S
- S
[Sold] '97 S70 T5
[Sold] '97 S70 T5
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
Engine running on with temp in normal range.
That was my complaint about a month ago.
Does it shut off after how long. I never let mine run long enough to run the battery down, but just unplugged it and plug it back in latter. That's when I noticed the wire were coming out of the plug, but still looked like they were plugged in. Two weeks ago I took the time to force the wires into the plastics plug and made a good connection, and have not had a run on fan yet. I hope my fix was that simple, as almost every time I stopped the car the hood would come up and stop the fan. At least check those wires.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
waffleshill
- Year and Model: 2004 V70R, 2006 XC70
No IAC. It has an ETM! Scan it with VIDA (if you can)! It will give you far more information than a generic code reader. The fan will run after shutdown if it is really hot out. I'd re-seat the ECM, maybe a contact isn't contacting. Also check all of your coil pack wiring on top of the engine.
2004 V70R Mystic Silver Metallic/Nordkap M66 287,000 miles
- 19 Replies
- 3556 Views
Last post by Chapelgirl
- 2679 Views
- 15 Replies
- 3190 Views
Last post by beigg
- 1233 Views
- 4856 Views
Last post by RickHaleParker
