1998 s70 multi misfire after replacing MAF and front02
raykan
Year and Model: 1998 S70 GLT => 236K
Post by raykan »
Hi everybody,
A couple of weeks ago my car failed to start. With the feedback of your I figured out the problem was MAF sensor.
Meanwhile, I also replaced the fron 02 sensorsince I was getting an error code for it for a long time. 02 sensor was Bosh however for MAF I had to go something much cheaper.
The car is generally running smooth however sometimes, he is so weak, like I don't have turbo just a base motor, then it is changing and being powerful again. Yesterday I began to get 2 & 5 miss fire codes.
Approximately, 4 months ago, because of miss fire problem, I had to change distributor, plug wires and spark plugs (all bosch) . Before that I did test all cylinders for possible pressure leak and they're okay.
My question, would it any direct relation between MAF sensor / 02 replacement and miss fires? and does miss fire explain power loss? ( i know just want to hear from someone else also)
Thank u for your time.
Ray
Veilleuxpbd
Year and Model: s70 2000
Post by Veilleuxpbd »
Have you checked the fuel pressure at the rail? Maybe a fuel delivery problem.
raykan
Post by raykan »
4 months ago, yes I did. pressure values were normal. However I didn't check them again after replacing 02/maf...
but worth to try again.
