crumbling wires-Nubie
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
rookedad
Post by rookedad »
I tried searching expecting a lot, but came up with nothing. I probably don't yet know how to use it correctly.
The wires to the fuel injectors have visibly crumbling insulation. I think it is the ground circuit. I believe I have seen something like this on Volvos before. Should I try to get into it, or will I open up an endless trap?
What is the reason for this problem? The car is a 1987 740 GL. Thanks for any help and/or enlightenment. Dan :?
DVolvoguy777
Post by DVolvoguy777 »
Check this guys site out:
http://personal.linkline.com/dbarton/WireHarnesses.html
He will give you great advice and get you a new or used harness. Most of the Volvo 240's wire harness will go bad due to excess heat and so on.
I am a current Volvo 850T5 owner. Have had '67 144ES, 71 142E, 76 245DL, 80 242GT, 81 245DL. Still wish that I had the 142E. :(
I scored an '06 Harley Dyna Superglide for Fathers day.
cosmiclobster
Post by cosmiclobster »
I have a 86 740 turbo. I bought it for 1/3 of the blue book value because, like yours, the insulation on the wires, especially the injector wires, would crumble off if you just touch them. I went to the junkyard and bought new wires with the injector plug on them and spliced them in. I also had to replace a half dozen other wires.
One of the reasons I got the car so cheap is because her mechanic told her it would cost $500 for a complete new wire harness and another $500 to install it. Out of maybe 100 wires, only 10 needed to be replaced. ll the rest were fine.
This was a common problem with only a few wires in that model year - at the junkyard I saw a few other cars with the same problem. But the injector plug stayed the same so get newer wires and splice them in - no problem!
Hope this helps!
