S80 2000
ROADRUNNER22
- Year and Model: S80/2000
Volvo S80
- Year and Model: 1999
- Has thanked: 7 times
- Been thanked: 2 times
Hi ROADRUNNER22,
Well when it comes to tune up it differs from the engine, transmission and drive train you have in your car, how much you want to spend on it, how much do you travel (long or short journeys) and do you plan to keep it for a long time.
The tune up that I do in my cars are:
1) Beginning tune up packet:
-Air filter,
-Spark plugs,
- Change Engine oil,
-Engine Oil filter,
-Etm Cleaning,
-Other fluids check/add level,
-Tire pressure check up.
- Check wiper blades,
- Lube door hinges,
-Check timing belt,
-Check brake pads,
-Check for any leaks.
2) Medium tune up packet:
- Air filter,
- Spark plugs,
-Change Engine oil,
- Engine Oil Filter,
- Etm Cleaning,
- Fuel Filter,
- Other fluids check/add level,
- Tire pressure check up,
- Lube door hinges,
- Check Bulbs,
-Check timing belt,
-Check break pads,
- Check for any leaks.
3) Advanced tune up packet:
- Air filter,
- Spark plugs,
-Change Engine oil,
- Etm Cleaning,
- Fuel Filter,
- Change transmission oil,
- Transmission filter,
- Change Brake fluid,
- Change Coolant,
- Drive train fluid,
- Replace timing belt,
- Brake Pads and Discs,
- Water pump,
- Serpentine belt,
-Rotate tires, pressure check and while doing this check suspension parts and replace if needed,
- Lube door hinges ,
- Check the bulbs,
Beginning tune up is if you plan to sell your car soon.
Advanced tune up packet is if you plan to take long journeys, if you just bought a car without service history that is in good condition or if you haven`t been investing on it for years.
Well this packets are more than just a tune up, I hope i could help you and address your needs.
Happy Motoring.
-Air filter,
-Spark plugs,
-Engine Oil filter,
-Etm Cleaning,
- Lube door hinges,
-Check timing belt,
-Check brake pads,
- Air filter,
- Spark plugs,
-Change Engine oil,
- Etm Cleaning,
- Fuel Filter,
- Lube door hinges,
- Check Bulbs,
-Check timing belt,
-Check break pads,
- Air filter,
- Spark plugs,
-Change Engine oil,
- Etm Cleaning,
- Fuel Filter,
- Change Coolant,
- Water pump,
- Serpentine belt,
- Check the bulbs,
Happy Motoring.
- 21 Replies
- 15852 Views
Last post by SOURDOUGHJIM
- 1284 Views
Last post by jimmy57
