Does anybody have a how to they could share on replacing the cv drive shaft in an 04 xc90 t6? I can't figure it out and there is no service manual available.
thanks!
How to replace CV Drive Shaft?
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Front or rear ones? Front driver's side one is sometimes stuck in there. I used the wheel lug wrench which happens to have a flat end, to pry between the transmission and the axle. You'll need to remove the axle bolt, remove the two lower strut bolts (have both front wheels lifted), then the shaft end should slide off the spindle.
I'm doing the front passenger side. I finally got the lower control arm off the ball joint. Now, I'm having trouble getting the drive shaft into the spindle and getting the control arm back on the ball joint.
- Been thanked: 504 times
Next time undo the control arm at the subframe side, it is much easier this way.
Tons of info in the P80 (Volvo 850, S70, V70) forum.
- 5217 Views
Last post by SuperHerman
- 1011 Views
Last post by JRev
- 3599 Views
Last post by bluesguys80
- 684 Views
- 3385 Views
Last post by DGB47
