Squeak and Creak Elimination (sunroof, moonroof, door frame, bushings, etc)
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
JNavas
Year and Model: 2008 S60 2.5T
Has thanked: 1 time
Been thanked: 3 times
Post by JNavas »
Never ever use silicone! It can make squeaks worse in the long run!
(Or WD-40! Or any petroleum-based oil or grease, including lithium grease.)
What you need is synthetic lubricant with PTFE.
  1. Best such product: Krytox GPL105 (or GPL104). Unfortunately, it can be hard to find and expensive.
  2. Next best product: Finish Line Extreme Fluoro Grease. While it's readily available, it's a grease that's harder to apply than an oil for squeak and creak elimination.
  3. Reasonable alternative: Super Lube Synthetic Oil With PTFE.
Image Image
Hope that helps,
John
2008 Volvo S60 2.5T (black with oak interior)
JNavas
Has thanked: 1 time
Post by JNavas »
Another option I just found: DuPont Teflon Non-Stick Dry-Film Lubricant
Available as liquid or spray.
Hope that helps,
John
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
How about Silicone Grease with PTFE for when the plastic door check gets greasy? https://www.amazon.com/Super-Lube-92003 ... 07BSNY44N/
It's compatible with basically everything (except silicone rubber): http://www.super-lube.com/files/pdfs/Su ... _Chart.pdf
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
JNavas
Has thanked: 1 time
Post by JNavas »
erikv11 wrote: 23 Jun 2018, 14:07 How about Silicone Grease with PTFE for when the plastic door check gets greasy? https://www.amazon.com/Super-Lube-92003 ... 07BSNY44N/
Avoid silicone in most automotive applications. It's not only bad for silicone rubber,
but also for paint and finishes, and is difficult to remove, plus many silicone lubes
have a petroleum base. Go with pure PTFE instead.
Silicone lubes work best for electrical insulation and plumbing.
Hope that helps,
John
Post by erikv11 »
Thanks for your insight. Against you're sound advice I'm going to go with it anyway. It's not "many silicone lubes" it is a specific SuperLube product, with a pure silicone base. Not petroleum based. Sounds like I'm fine if I keep it off the finish. Difficult to remove can be a good thing, too. Not really interested in buying another product, the chemicals aisle is my least favorite part of working on the car ...
'06 S60 R, 197k
JNavas
Has thanked: 1 time
Post by JNavas »
Super Lube Silicone Grease is not compatible with silicone rubber, some plastics, or many finishes, and removal difficulty is not an asset. It.is great on gaskets, valves, o rings, and electrical connections, but is not a good general purpose automotive lubricant. Super Lube Synthetic Oil With PTFE (as in my original post) would be a better choice. But all that said, if you're careful not to get it on finishes, you're probably okay with Super Lube Silicone Grease .
Hope that helps,
John
