The saga continues:
I followed everybody's advice from a previous post, and replaced the ABS control module. The symptoms I was getting were flashing shift light, check ABS light, trac. control light, then the speedometer started to not work periodically. Now that it is replaced, the check engine light is on and the up-arrow is still flashing. Any ideas?
Thanks
2000 v70 ABS control module
You need to read codes and post them back here - format P1234.
This morning, one of my employees told me Autozone no longer will read codes for you here in NY? I can't believe this makes sense but heard it from reliable source. Maybe our local store got tired of people driving off with their code reader.
kahl
- Year and Model: 2000V70XC
- Been thanked: 10 times
Read the code and clear the code. See if that clears up the arrow. See if code comes back. I think on a 96 I had I had to erase the code after I installed a replacement module from Matty. The code was a tranny code and erasing the code squared everything away.
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
You let the old module go too far where it triggered tcu and ecu codes. The tcu won't report back to the ecu saying that everything is fine so you have to clear them with a scanner.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Matty Moo
I'm not sure that theirs will access the tcu.
2000 s70 GLT
2014 Ram
I'm a long hour west if you run out of luck with AZ or the TCU, but with one of the kids ar Smith I'm often by your area.famfeld wrote:Heading out to Autozone this week to borrow scanner tool. Here in the "Happy Valley" of Western Mass they still lend or let you use them. Thanks
I think my 801 will deal with the TCU but I have MTCU on my cars
- Year and Model: Many Volvos
- Been thanked: 76 times
So how do you reset the MTCU?abscate wrote:I think my 801 will deal with the TCU but I have MTCU on my cars
- famfeld
- Year and Model: 04 xc70
- Has thanked: 9 times
- Been thanked: 6 times
abscate wrote:I'm a long hour west if you run out of luck with AZ or the TCU, but with one of the kids ar Smith I'm often by your area.famfeld wrote:Heading out to Autozone this week to borrow scanner tool. Here in the "Happy Valley" of Western Mass they still lend or let you use them. Thanks
Let me know is you'll be in Northampton and I'll meet you out there if you don't mind. Autozone has an obd2 sensor that they will run on my car, but they didn't know anything about a TCU. I would be interested in buying the scanner if its reasonably priced. I would like to learn how to reset the codes. I'm pretty sure that the code is from transmission since the tranny did all kinds of weird stuff when the module was bad. I also was using gears 1,2,3 etc. when the car wouldn't shift on its own and it would make a loud noise when I changed the gears at times. Anyway thanks and please let me know.
- 11 Replies
- 7080 Views
Last post by Vovoroom
- 2220 Views
Last post by yagger
- 2062 Views
Last post by yagger
- 6025 Views
Last post by misha
- 2641 Views
Last post by FreshAirInspector
