2006 V70 2.5T P0101
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
2006 V70 2.5T P0101
Post by obayha »
Code is telling me the MAF is bad or going bad. Car starts a little rough, but was able to go to Auto Zone and have code read. Does this MAF work like the one on my old '98 V70, when it went bad I was able to unplug it and still drive home? I am thinking at 124,000, it is on the way out and I should not try and clean it and get a few more miles out of it.
Thanks for any help.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
JudgeRat
Year and Model: s60 2004
Has thanked: 3 times
Post by JudgeRat »
You could be correct that you need a new MAF, but that code seems to indicate that there could be an air leak as well. It might be worth the time to check to see if you have a leak and/or bad seal somewhere in the MAF feed.
"Molly" - Black 2004 2.4L i5 (non-turbo) T5 Auto FWD P2 Volvo s60 w/all options
Old-school race guy: "Brakes 1st, then steering, tires, wheels, & suspension, only then engine and drive-train. No sense making it go if you can't stop & steer properly...Safety first people!"
obayha
Post by obayha »
Thanks.
Went and picked up a reman at Auto Zone last night and installed, so the lady wasn't left stranded today. Will see how it does. I was wanting to know if it did cut off, if you could just unplug and it would still run like my '98 did?
Showed her how to do the unplug this morning, just in case the AZ failed.
obayha
Post by obayha »
Wife just called. She was doing some stop and go around town today and after about two hours, the car started acting up again. Going to pull the MAF and get the second one from AZ tonight and try it.
terryjr
Year and Model: 06 XC90 - 04 XC70
Post by terryjr »
ive been chasing a p0101 too, but i have a p0701 to go with it. i replaced maf and pulled up my scanner to read the maf signal, it appears to be in range. I came across a thread suggesting dirty injectors so yeasterday i poured in some cleaner. Its wait and see time.
I noticed while reading maf signal that my short term fuel trim was erractic, to me that means, A, the car was getting inconsistant fuel, or B, the 02 sensor was acting up, but no o2 code so i starting believing it may be a misfiring injector.
JudgeRat
Post by JudgeRat »
That P0701 code is for "Transmission Control System Range/Performance"
obayha
Post by obayha »
So far mine has been solved with the second MAF from AutoZone. Went on a 500 mile trip last weekend and seemed to do good. It has a year warranty. Hope it last longer than that. The engine light did turn off on it's own. Guess that is on the newer models, not the '98 I had.
Best of luck with the P0701, not sure what that one is, other than what JudgeRat has said.
Shane
JudgeRat
Post by JudgeRat »
I believe he got that one dyslexic and it was really a P0170 - Fuel Trim Malfunction (Bank 1) as he indicated in a post on a different thread.
Of course, if it was a:
P0107 - ECM‑1000 - Control module - Signal too high / signal too low. Intermittent fault
P0107 - ECM‑1000 - Control module - Signal too high / signal too low. Permanent fault
P0107 - Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
, that would be a completely different can of worms.
This points out why it is so very important that we be precise in our posts. :shock:
terryjr
Post by terryjr »
Sorry about the typo. Glad the second MAF fixed it. Ours has been better too since we put the fuel cleaner in.
obayha
Post by obayha »
Bringing up my old post as it has appeared again. A little over a year and a half latter. Noticed engine lite on and another read shows P0101. Should I ASSUME ( we all know what that means) the MAF has gone bad again? Any better places than Auto Zone to try.
Thanks for any thoughts.
Shane
