Will a V70 headliner fit an 850
skloon
Year and Model: 94 850 95 850 04 S60
Been thanked: 2 times
Post by skloon »
saw a decent v70 headliner and the one in my 850 wagon has to come out to replace the sunroof, are they exchangeable ?
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
You can take the sunroof out without removing the headliner. https://www.matthewsvolvosite.com/forums ... 0393#30393
As far as the headliner goes I think it might. If you can check to make sure the grab handles, sun visors, and rear clips are all the same on both cars then I think you can reasonably assume the headliners can be swapped.
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Yes. I put one in my car. Be sure to clean out the cabin fans.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
I believe the climate control temperature sensor will not match. 850 has em in the headliner, V70 doesn't.
If I'm not wrong about that, you can probably make a cutout in the V70 headliner to match, but I'd look closely at both parts before taking the dive.
skloon
Post by skloon »
My sunroof has broken tracks so I have to drop the headliner- I will check it before I yank it out- I did pull my fans and clean the plug of crap out of them -luckilly a wagon so easier to pull the liner and it is half price at the yard
bob850
Year and Model: 1996 850 Turbo wagon
Post by bob850 »
Did the V70 headliner fit into the 850? If so, how did you deal with the climate sensors by the front grab handles?
I need to replace my 850 Wagon headliner and wondering if this is still a good option.
1996 850 Turbo Wagon - 175K miles, ARD Green ECU, Koni FSD, IPD sways, Snabb intake pipe, IPD HD TCV
1999 V70 T5M - 220K miles, M56H swapped, 2004 S60T5 engine, IPD sways, H&R springs, Bilsteins, TME catback, tune
2007 V70R, 55K miles, mostly stock
skloon
Post by skloon »
Somebody ripped it up before I got to it, I recovered mine- not a good job I did it outside in the sun and the contact adhesive got all lumpy
