Volvo 850 GLT na clutch options
TrevorVolvo
- Year and Model: 1995 850
My clutch has started slipping in my na 850 and was wondering if a t5 or t5r clutch will fit? My mechanic said he thinks the spindals are different sizes. I want to do a t5 swap when this na engine goes so it would be nice to have a t5 clutch already in there.
- Year and Model: Many Volvos
- Been thanked: 76 times
The splines are all the same. I just bought a standard Sachs kit when I changed mine but the surface area on the clutch disk was noticeably smaller on the replacement than it was on the original but it works just fine.
TrevorVolvo
Did you put the standard Sachs kit into a turbo model?
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I just had to replace a clutch on a V70 non-turbo. I ordered a Sachs kit from FCP and the clutch that came in that kit was for a turbo model. I was able to see the old clutch that had come out of the car with the new kit and the parts for the non-turbo are definitely different fro the turbo kit. Could the turbo clutch have been used in the non-turbo? I don't know, but I'll be sending the turbo kit back and using a non-turbo kit instead. There are definite differences in the parts. The biggest thing I noticed (and I probably won't get the terminology correct) is that the clutch disk (friction surface bearing part) has four embedded springs on the non-turbo part that are missing from the turbo part.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
TrevorVolvo
So when people swap the na 5 speed transmissions into a t5 or swap the t5 into a na what clutch do they use?
Will a new na clutch be able to handle a turbo?
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
The clutches are interchangeable. When swapping the 5spd into a turbo people will use a turbo clutch.
Generally not recommended.TrevorVolvo wrote:I want to do a t5 swap when this na engine goes so it would be nice to have a t5 clutch already in there.
- 931 Views
Last post by 93Regina
- 28 Replies
- 8996 Views
- 35 Replies
- 17198 Views
- 346 Views
Last post by 1ezliving4ume
- 20 Replies
- 7403 Views
Last post by Klausc
