Just Got a V70 Wagon and noticed a fuel smell inside the cabin just after filling up. Smell stays the same while driving... Well...at least when It was operable. Currently, Its in "bent valves, head rebuild mode" in my driveway, (Fun Times...Fun Times).
I am sure there are numerous things to check besides fuel filter and fuel rail Valve seals (both seem good). What are the other things to check?
Thanks
Nathan
Fuel Smell
stephansvolvo
- Year and Model: V70 GLT 1998
- Has thanked: 21 times
- Been thanked: 3 times
start at the fuel inlet. There are hoses that are accessed throught the floor in the backseat. These hoses split and will allow the fuel odor into the cabin. I have the same issue and have not handled it as of yet. But will have a new house with a garage again northwest doesnt bode well for winter repairs without a garage.
Stephan
Stephan
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
98 S70 GLT
73 IH Scout ii
nthnnxn
- Year and Model: 2000 S70
- Has thanked: 3 times
- Been thanked: 4 times
[quote="stephansvolvo"]start at the fuel inlet. There are hoses that are accessed throught the floor in the backseat. These hoses split and will allow the fuel odor into the cabin. I have the same issue and have not handled it as of yet. But will have a new house with a garage again northwest doesnt bode well for winter repairs without a garage.
Sounds like fun... Thanks!
- packetfire
- Year and Model: 2010 v50 2.4i
- Has thanked: 17 times
- Been thanked: 30 times
Agree with the above, but be warned that you want to disconnect the battery before looking at this, as the rear seatbelts are often unplugged when getting at the fuel pump, and will trigger SRS (airbag) warnings, which are a pain.
It is likely the o-ring gasket on fuel pump, or the pump itself.
Sorry about the bent valves.
1982 240DL: Drove it 32 years and 1.5 million miles (sold, even still had mint leather!)
2001 v70 2.4T: The most expensive $1500 car I ever bought ("Volvo Turbo" - what an oxymoron!) (sold)
2004 v70: Far less fatally-flawed v70 - It served well (sold)
2010 v50: Smaller, slightly sportier wagon. Its got a spoiler, so I upgraded with sway bars!
nthnnxn
Ok. So I have located the gas leak coming from the driver side gas of the gas tank (access panel under driver side back seat). I am guessing there is a seal underneath the lock ring? I am unable to get it off so far... Assuming I get it off will there be an o ring (i cant find one online, just fuel pump o ring) or will I need to seal it another way? Or is there some other crazy problem?
...Cylinder head went to the machine shop today
Thanks
Thanks
- 16 Replies
- 10551 Views
Last post by EdRedSled
- 2148 Views
Last post by precopster
- 404 Views
Last post by matthew1
- 5352 Views
Last post by 70bronco
- 1025 Views
Last post by adriggs1
