850 Dimmer Switch
warmblood58
- Year and Model: 1989 245
- Has thanked: 5 times
- Been thanked: 2 times
Pulled 5 dimmer switches at a picnpull and not one would function so I pinned ports 1 and 4 from the backside and reinstalled switch which is on full. We have an excellent electronics supply house in our area. I am going to open switch and take to store owner to see if he can recommend a fix - - - I find it hard to believe that these switches cannot be repaired somehow - I will report back with results
- Has thanked: 311 times
- Been thanked: 817 times
Sorry, I am not following. Are you saying all 5 switches are bad?
That would be bizarre, I've never had one go bad, even have extra good ones. Not saying they don't fail, you can find posts about it, but it is uncommon.
warmblood58
Yep, all 5 toast . . . no dimmer function which is why there are so many posts about bridging 1and 4 terminals on the switch. New dimmers are (850) over 150.00! Crazy!
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
What exactly is the problem you're having here?
If it's full on dash lights with no dimmer function
using 5 different dimmers, that would suggest
another issue in play.
If so - What do you get with no dimmer plugged in?
warmblood58
I get no dash unless I pin 1 and 4 - My understanding is that the dimmers fry and then there is zero function as there is no connection through switch which is why people pin 1 and 4
- BEJinFbk
Yeah, but FIVE bad dimmers? That just doesn't add up.
What do you see for voltage on pin 3 with the headlight
switch in the "parking lights on" position?
warmblood58
You realize that I am talking about the dash light dimmer switch not the high beam flash arm stalk?
- BEJinFbk
Yup. Here's what you should have at the dimmer connector:
Pin 1 - Brown/Orange - !2 volts from the ignition switch.
Supplies switched power dimmer when the key is on.
Pin 2 - Black - Ground.
Pin 3 - White - 12 volts when On from the headlight switch.
Provides 12 volts when the parking lights should be on.
Pin 4 - Pink - Dimmer output to all instrument lamps.
Pin 5 - White/Black - Ground when Off from the headlight switch.
Pin 6 - N/C
You also have a few posts describing some other electrical issues.
You may be dealing with some trouble from aftermarket work.
Check ALL the fuses in the car and find out what that black
fuseholder under your hood is for.
Pin 6 - N/C
This! 6 bad dimmers (including your original) out of 6? No way.BEJinFbk wrote:Yeah, but FIVE bad dimmers? That just doesn't add up. ...
I'm no electrical troubleshooter, there are few better than BEJ for that I would give him a listen. But anyway if all 6 are truly bad now, then I would be wondering why your car is cooking them, not opening up the switches.
warmblood58
no, you misunderstood. My car had a bad dimmer switch, apparently they fail after some years of use. I harvested another five from pic n pull cars -these too were bad -
