Considering a Volvo - "Lower Gasket Leak with smoke"?
mtd240
Year and Model: 2007 XC70
Has thanked: 23 times
Been thanked: 7 times
Post by mtd240 »
It's been awhile since I posted here (been awhile since I owned a "newer" Volvo :P). Looking at picking up another '98 XC. Guy says the engine is "blown", according to his mechanic (who apparently knows a lot about Volvos). Car starts and runs, then starts smoking a lot after a little driving, through the cabin even. (it's not the heater core)
The mechanic told him it is a "lower gasket" that would require pulling the engine to replace. I am having a hard time believing that..it's been over a year since I last worked on one of these, but memory tells me there aren't any "lower gaskets that require engine removal". Seals maybe - rear main - but no gaskets. It was hard to figure out what was wrong, but my best guess is that something is leaking onto the exhaust and burning off.
Now the question - is the oil pan gasket right above the exhaust? I can't remember. A better guess would probably be a seal (or two [or three]) leaking oil onto the turbo - cam, oil cap, or even a turbo seal of some sort (don't remember much of what's back there). Clogged up PCV. Car probably just needs a little attention at 175k miles.
Anyway - opinions?
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it :lol:
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
You recall correctly, the engine stack only has one "gasket", the head gasket. The other layers are sealed with anaerobic sealant. Also, there is nothing above the exhaust that would leak oil. Most likely would be turbo seals or O-rings on lube lines to/from turbo. How fast does it consume oil? Does it start immediately and run smooth?
Rear main would cause a drip or puddle on the floor, not a cloud. Rear cam seals might allow oil to get blown to the exhaust?!
Run a compression check and block-check the motor for basic peace of mind, then go crazy fixing every little thing on it!
Current Volvos:
Has thanked: 2199 times
Been thanked: 1852 times
Could be the PCV is blocked and forcing oil into the top of the head and then it eventually works its way out the back top cover and drains down the back of the engine. May explain why it takes a while to start as it needs time to build pressure after starting. Other suggestions from FLX90 also stand. Even the oil filler cap seal leaking for a long time can do this.
mtd240
Post by mtd240 »
Thanks for the replies guys. So, probably PCV or turbo. Actually, probably both, after 175,000 miles.
I can't really ask the guy too many more questions - I think I asked too many up front ha! I'll try to figure out if it runs smooth - I doubt he knows how fast oil is disappearing (he doesn't even know if oil is disappearing). I'll go take a look at the car, and check PCV pressure and do a compression test. Perhaps make sure the driveshaft is still in, too..
He only wants $400 for it - so if the body and interior are in good shape, and it doesn't have major rod knock, I'll probably pick it up.
Gone:
mtd240
Post by mtd240 »
Sorry to post multiple times.
I asked the seller if it ran smoothly. He said yes, until it starts to overheat, hiss, and idle sporadically :lol:. I just can't figure this guy out. Anyway, I'm guessing headgasket now, for sure. Still worth the $400 though, I think.
Gone:
bugs11
Year and Model: 850 1996
Post by bugs11 »
Check for exhaust gases in coolant.
Has thanked: 1609 times
Been thanked: 4065 times
mtd240 wrote:Sorry to post multiple times.
As a parts car. For the cost of getting a daily runner, I would look elsewhere.
FLXC90
Post by FLXC90 »
Block-chek, available at NAPA, or "rentable" at auto parts stores, checks coolant overflow tank for exhaust gas. Sounds like this car has a breached gasket.
If it is immaculate (for a 15-20 year-old car), then maybe find a crashed good runner to harvest a motor from, or just keep looking.
Is it a car, a hobby, or an addiction? :D
Current Volvos:
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
FLXC90 wrote: ... Is it a car, a hobby, or an addiction? :D
Almost unanswerable!! :lol:
OP you have experience with AWD so I defer to you but I think I wouldn't go for an engine pull on one of those, I would save my efforts for a nice T5.
