Electrical Problems... Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Dethsman
Post by Dethsman »
I have a 1979 DL245 Wagon. When the key is in the "on" position, all the electrical systems will work (wipers, radio, backup lights) yet when the engine is running they will not work. THe lights still work however. Thanks in advance for any suggestions!
arete
Post by arete »
With the engine running try slightly tweeking the ignition key. It might be just a short in the ignition system. It is with my 81 240.
Volvord
Post by Volvord »
Very common problem, when you start the car and release the key it does not fully return to the "run" position. To fix just rotate the key slightly counter clockwise ... just a bit. Try putting a little graphite into the key slot for lubrication but it is usually the ignition switch that is sticking and may have to be replaced
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
