If you replace front pads only, how does a garage make sure that the front brakes match in tightness with the rear 50% worn pads?
Furthermore, if front wears faster, doesn't it mean that when they wear, they will be looser and touch the disc/rotor later than the rear?
how to match front and rear brake tightness?
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Unlike the old drum and shoe type of brakes, today's disk brake pads ride very, very close to the rotor. Once the new pads are installed and the pedal is depressed a couple times, all of the pads will seat against the rotors. So when you're driving and hit the brakes, all of them will apply friction against the rotor at the same time.
the piston does not retract.
the calipers slide on the brackets.
as the pads wear the piston remains extended and the caliper slides so the outer pad moves as well.
There's no adjustments to be made in a disc brake system, unless there are integrated parking brake things, which we don't have.
qwertyjjj
- Year and Model: V70 2004
- Has thanked: 1 time
They self adjust to distance away from the disc?chrism wrote:Unlike the old drum and shoe type of brakes, today's disk brake pads ride very, very close to the rotor. Once the new pads are installed and the pedal is depressed a couple times, all of the pads will seat against the rotors. So when you're driving and hit the brakes, all of them will apply friction against the rotor at the same time.
- Been thanked: 4064 times
Correct.qwertyjjj wrote:They self adjust to distance away from the disc?chrism wrote:Unlike the old drum and shoe type of brakes, today's disk brake pads ride very, very close to the rotor. Once the new pads are installed and the pedal is depressed a couple times, all of the pads will seat against the rotors. So when you're driving and hit the brakes, all of them will apply friction against the rotor at the same time.
Drum brakes use springs to pull the shoes away from the drum, so that the clearance between shoe and drum has. To be adjusted periodically. Disc brakes self adjust.
