Volvo 850 GLT Bulb Failur Lamp
The bulb failure lamp on my 97 Volvo lights up when brakes are applied. I replaced the rear bulb failure module, beneath the rear driver side light cluster, and nothing changed. Then removed the park light and the bulb failure lamp is on. So I have confidence that the bulb failure module is ok. Looking at the wiring diagram I don't see another possible cause. It has to be related to the brake pedal being depressed ...but how? Any suggestions? Thanks, wlutz.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
Is it the correct bulb failure module? they make at least 3 differnt ones: 2 brake lights, 2+3rd being a bulb, 2+3rd being led (V70).
i sometimes get a bulb warning before hitting the brakepedal after startup.
Maybe the brake light switch at the pedal has too high of a resistance? Or one Connection to a brake light is corroded somewhere?
1996 855 R,
2010 V70 D5,
2010 V70 D5,
crlande
- Year and Model: 240DL;850;S70
- Has thanked: 1 time
- Been thanked: 36 times
Are you sure the brake light bulb filament is not burned out? On my car applying the pedal and the dash lighting up always meant I had a burned out bulb.
- Has thanked: 311 times
- Been thanked: 817 times
Two common causes:
- What about the "third brake light" in the center back window, is it working properly?
- Check for corrosion in the bulb sockets, and if the correct bulbs are installed.
It's embarrassing but I was not aware of a third brake light. The wife and I had taken turns pressing the brake pedal and monitoring the two brake lights...our eyes and mind were focused on the two brake lights. I removed the lamp cover then pushed in the middle under the lamp assembly and pulled it off its track. The bulb was fine but there was a layer of grey oxidation on the contacts which I scraped off and reinstalled the whole thing and it works and the lamp fail indicator is gone. Thanks to all and especially erikv11. wlutz
I have also been stumped by the third brake light. It's like a riddle, once you know the answer ...
Music to our ears.wlutz wrote: ... it works and the lamp fail indicator is gone ...
- 1077 Views
Last post by Ozark Lee
- 1014 Views
Last post by Chico
- 4867 Views
Last post by adrian22
- 4140 Views
Last post by silentcircuit
- 2635 Views
Last post by firstv70volvo
