valve cam cover gasket
correllkp
Year and Model: 1995 850, 1996 960
Been thanked: 3 times
Post by correllkp »
Hello.
This past winter I had my cylinder head resurfaced at the local machine shop. Now that the weather is warmer I am putting everything back together. It seems to me that when I removed the cylinder head there was a metallic gasket under the valve cover (had two humps at either end). I don't see one now...the machine shop probably threw it away. But, I don't see a replacement in the kit I purchased from FCP. There is a flat flexible gasket which according to instructions bends around the humps. Is that all there is? No semi-rigid metallic gasket?
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
correllkp wrote:metallic gasket under the valve cover (had two humps at either end)
When Volvo transition from B23s to B230s series engines, there was a difference in valve covers.
What's FCP part number? Got pictures?
There is a metallic "sheet" between the head and the block, but not between head and valve cover.
Tip of the Day - "As a matter of fact, I have never used silicone sealer on any European engine. I use non-hardening gasket sealer such as the aviation type."
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Hey! I posted that tip.
1988 Volvo 760 Turbo Wagon
93Regina
Post by 93Regina »
lummert wrote:Hey! I posted that tip.
Well, Andy Warhol said, "In the future, everyone will be world-famous for 15 minutes"
