Pls help n gimme solutions asap. My Volvo s80 once I start it, d P on d dash shows n once I move it coming to 3rd gear it drags n makes a jerky sound n at that point, d dash display instead of show P, or D, it shows a -, Dats a minus sign n den immediately, d car starts crawling like a car whose clutch is burnt. Then wen I off n start, d P comes on fine but once I move it jerks cum clunck harshly n d minus sign comes on n crawling sets it.
Took it for diagnosis n read Transmission speed line missing..... Whatever that means. Some mechanics suggested its d fibers gone, some say I shud buy another gearbox, some say its d Throttle Board. Av changed gear oil still d same story. Pls wat do I do? Its a 5cylinder, front wheel drive 03 Volvo s80, with dutch text display.
Transmission problem
precopster
- Year and Model: Lots
- Been thanked: 128 times
Looks as thought the 3rd gear friction band is worn beyond limits. The - sign means it can't find a gear. You can manually shift if you have geartronic by avoiding 3rd gear.
Repairable with about 12 hours of labour and a DIY mindset.
Catch this link: https://www.matthewsvolvosite.com/forums ... nd#p341412
Tanx a lot but mine has no manual shift. Worse off is at stop lights, wen I want to move I Haf to heavy throttle before it starts crawling, it responds faster wen moving from a standstill with d gear in L but changing from L to 3 or D jolts cums jerks seriously as if something hit d gearbox. All I do is drive slowly until speed picks up n I don't go beyond 80km/hr. But once I off n start, d P shows n takeoff is fine n once u want to accelerate u hear bad jolt sound n - appears n car crawls. During all these d dashboard hazard light still lights Orange, not Red. Am planning on buying a good used tranny.
precopster
Transmission is in limp mode. This makes it start in 2nd or 3rd gear.
If you keep driving it without repair you'll fry the gearbox and need a new one.
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
let me know if you need any help translating Dutch display messages. Good luck with the fix
Pls anyone help, if I want to buy a used Volvo xc90, of 05/06 which engine type wud u advise me to buy that will b durable n fuel efficient? Cos I love certain things in Volvo like d air con vents which stretches to d rear, d door lights, d light under d side mirrors, etc.
Cees Klumper
Versnellingsbak service vereist = transmission needs service.
Yes, I also thought later that Google translate probably gets tou 90% of the way. Good luck with the fix,
- 15 Replies
- 7854 Views
Last post by tango_1000
- 1319 Views
Last post by alschnertz
- 1700 Views
Last post by rasense
- 2238 Views
Last post by tryingbe
- 3021 Views
Last post by mayfair
