2004 XC90 coolant leak
ductclean
Year and Model: 2004 XC90 T6
Post by ductclean »
Need help! 1st post with my wife 04 XC90 T6 overheated tonight seems most of the coolant leaked out....the item circled had blown apart and coolant leaked from it...was able to put rubber switch? back in and twist lock it back on. However it seem to me the lock is broken...need help identifying the part/item so I can locate and purchase and get back on the road!
Thanks
Gary
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Hello Ductclean,
The part in question is the Brake Booster Vacuum Switch.
You can find it on our site here: https://www.fcpeuro.com/products/volvo- ... 0-31265826
This unit does not hold any coolant however so you most likely have another issue.
If your ever in need anything else, you might want to try our brand new OEM Parts index.
You can find it here: http://www.oempartsindex.com/
Thanks
Jason
