Any help you can give would be greatly appreciated, single mom in the boonies, need my car runnin pretty bad
Camshaft codes/ no start problem
YoungHottie916
- Year and Model: 2001 S60
So I recently had alot of work done on this 01 volvo s60, the water pump, thermostat. Radiator, timing belt, serpentine belt, spark plugs, coil packs, heater core hoses, and it is having problems again. Started out starting fine but only staying runnin while givin it gas, so I replaced the maf sensor only to find a huge hole in my innercooler hose, so I replaced that, ran fine for a day then wouldn't start, had it read on code reader and it threw ALOT of codes. Camshaft control, camshaft position sensor, TC system flow fault, TP sensor 1&2, torque, and MAF sensor (replaced but didn't clear code )
- 621 Views
Last post by YoungHottie916
- 1965 Views
Last post by cn90
- 1977 Views
Last post by RickHaleParker
- 1443 Views
Last post by renegade343
- 19 Replies
- 10313 Views
Last post by Barledge
