Camshaft codes/ no start problem
YoungHottie916
- Year and Model: 2001 S60
So I recently replaced alot of parts in my 01 s60, water pump, radiator, thermostat, heatercore hoses, radiator hoses, spark plugs, coil packs, timing belt, serpentine belt, coolant level sensor, was running great. Then all of a sudden it would start fine then sputter an die, I replaced MAF sensor, only to find a huge holr in my innercooler hose, replaced that, and it ran fine for a day. And now won't start, it tries to turn over but won't start, I had it read and its throwin 6 codes: MAF sensor (replaced but didn't clear code) Camshaft position sensor, Camshaft control, Turbo control system flow fault, Throttle position sensor 1&2, and Torque. Not sure what to do I have a position sensor on the way. I removed the timing belt cover to look at cvvt solenoid and oil appears to be lraking from it pretty heavily, so I purchased one, but it's an expensive part and wiring the housing plug doesn't look easy. I'm no mechanic just a single mom that grew up around mechanics tryin to use the little i know to get by.. I NEED HELP any info is greatly appreciated ty
YoungHottie916
~YoungHottie916~
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
Wow, that's a whole bunch of fault codes to suddenly show up. And I'm struggling to see a relationship between some of them. By any chance, did you have the Engine Control Module (ECM) pulled out or possibly mess with the wiring to/from it?
YoungHottie916
No, never
- 457 Views
Last post by YoungHottie916
- 1965 Views
Last post by cn90
- 1977 Views
Last post by RickHaleParker
- 1443 Views
Last post by renegade343
- 19 Replies
- 10313 Views
Last post by Barledge
