2004 s60 Radiator Cooling Fan Issue
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Ziggy
Year and Model: 2004 s60
Post by Ziggy »
Hello,
My radiator cooling fan for my 2004 s60 is not working. I suspect that the problem is with the signal from the ECM to the Fan Control Module. The battery voltage is there for the fan, but there is no signal even when the engine temperature is over 220 F. Does anyone know what the signal to the Fan Control Module is so that I can apply it for a test? Voltage? Ground? 5 Volt Signal?
Thank you,
Ziggy
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Can't answer but at 13yrs old the module can fail, mine did. It should turn when the a/c is on
Brentscrazyptwo
Year and Model: 2004 S60 2.5T
Has thanked: 11 times
Post by Brentscrazyptwo »
Hi, were you able to solve this issue? My 2004 S60 2.5T is ha ing the same issue. The dealership was no help as I have a new fan unit and they could turn it on via their VIDA. Any help would be much appreciated.
