Hi,
I was wondering if anyone has ever retrofitted a auto dimming rear view mirror into their v70 preferably using the factory mount point. I saw it listed in a Volvo accessory catalog but I imagine that one is long discontinued.
Auto dimming Rear View Mirror Retrofit Topic is solved
JRL
- Year and Model: Several
- Been thanked: 16 times
If you can find one, most 2000s are pre wired. Not sure about 99s
Here's a thought would a C70 mirror fit?tryingbe wrote:http://www.ebay.com/sch/i.html?_odkw=94 ... g&_sacat=0
I never found flipping that little switch was inconvenience.
2000 V70XC 160,000mi.
tryingbe
- Year and Model: None
- Has thanked: 1 time
- Been thanked: 26 times
Time for your to experiment and find out.m96ag wrote:Here's a thought would a C70 mirror fit?tryingbe wrote:http://www.ebay.com/sch/i.html?_odkw=94 ... g&_sacat=0
85 GLH, 367 whp
00 Insight, 72 mpg
00 Insight, 72 mpg
At first glance the mount points appear to be the same. So here goes nothing!tryingbe wrote:Time for your to experiment and find out.m96ag wrote:Here's a thought would a C70 mirror fit?tryingbe wrote:http://www.ebay.com/sch/i.html?_odkw=94 ... g&_sacat=0
Last year I replaced the busted (running fluids) OEM one in my '98 C70. The original unit was made by Donnelly, which appearantly supplies a lot OEMs with auto dimming mirrors. I found out that my model (model no. 011530) was used at least until 2005, for Acura TL's. As the fluid in these eventually all go bad, I'd suggest getting the youngest used one you can find.
For instance this one, matches mine. You'll have to replace the mirror assembly from the old non-auto dimming one (which is quite a pain - maybe there's a trick to it I didn't know) and the connectors.. or find a way around that. It basically just takes 12v I guess?
I ordered a C70 mirror. I just need to find out if my car came prewired with the connector. If not I'll have to use the accessory connector for switched power and ground and then tap the existing courtesy lights if I want those to work.thijsj wrote:Last year I replaced the busted (running fluids) OEM one in my '98 C70. The original unit was made by Donnelly, which appearantly supplies a lot OEMs with auto dimming mirrors. I found out that my model (model no. 011530) was used at least until 2005, for Acura TL's. As the fluid in these eventually all go bad, I'd suggest getting the youngest used one you can find.
- 2226 Views
Last post by konielian
- 1670 Views
- 660 Views
Last post by Lucky_Seven
- 1152 Views
Last post by phils94850
- 1027 Views
Last post by jimmy57
