I have a used replacement rear view mirror, ready to go into my car. Is there a way to test it? I guess it would be putting DC voltage through the pins but does anyone know what voltage that would be?
Thanks
How to test auto darkening rear view mirror
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Maybe place a flash light just in front of it ? Or even a cigarette lighter
azureblue
- Year and Model: 2014 S60 T5
- Has thanked: 16 times
- Been thanked: 8 times
The mirror is removed from the donor car PC board. There are two pins on the back of the mirror itself, not the assembly or the PC board, that I want to test from. Before I solder it to the original PC board..... sorry I should have been clearer
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
- RickHaleParker
- Been thanked: 958 times
The mirror is not in the wiring diagrams. Nobody can give you a safe answer. Your best course of action would be to measure the voltages on the PC board to get your answer.
- Has thanked: 1505 times
- Been thanked: 3818 times
Isn't it just a photocell which biases crossed polarizers? That doesn't need external voltage.
A strong flashlight should do the trick.
- RickHaleParker
The LCD needs energy. The dimming is a unmasked LCD blocking light from reaching the mirror.
The Photocell provides the Potential - like a real old camera light meter using CdS - no batteries, the light generates the voltage needed to dim the LCD. Thats what mine looks like, but I don't have any more info than the visual
- RickHaleParker
The mirror does have Photocells however, a Photocell is not a Photovoltaic cell.
- Photocells are light sensitive resistors.
Photovoltaic cells aka Solar cells convert electromagnetic radiation into electrical energy.
I think I messed up the history of detectors. The standalone meters were Selenium, the CdS cells were the first battery operated ones.
I doubt they are using Selenium but some sort of PV would do this.
