One of my remote FOB for my 97 850 doesn't work. It doesn't make any sounds and I changed the battery.
I opened it but didn't see anything obvious wrong with it. Any common issues?
Second question: If my other remote FOB fails, is there a way to bypass the alarm and start the car? Or does it leave you stranded?
97 850 Remote FOB
- Has thanked: 2199 times
I'll have to go out and try, but as you don't have a chipped key, have you tried just unlocking the door with the key and starting the car normally?
- Has thanked: 311 times
- Been thanked: 817 times
Neil is right, you can just unlock it with the key. If there is any issue, first lock (or re-lock) it then unlock it.
One issue I have dealt before is the button(s) getting gummed up; in that case they will be noticeably sticky and not clicking well. I have fixed them by pulling the board out and then working the button up and down while in a little bath of 100% rubbing (isopropyl) alcohol. Just let it evaporate well before you reinstall the batteries. I haven't used 70% isopropanol on electronics, the amount of water in there worries me.
