154 code after radiator change Topic is solved
swe280Z
- Year and Model: 1994 855 NA mfg 9/93
- Has thanked: 2 times
I recently changed my '94 855 NA radiator and a temporarily-patched air inlet hose. The car was running great(105K) but I got a 154 code a day or two later. I cleared it but it comes back after a few minutes. I may have swapped the small hoses above the fan shroud when I reinstalled it. I also have a slight miss at idle along with the 154 code. Does anyone have a picture or drawing of the small hoses that run up to the top of the shroud related to the EGR? I should have labeled them instead of relying on my 70-year-old memory! Thanks in advance.
- Has thanked: 2200 times
Most Volvos should have a vacuum layout sticker under the hood. Have you checked there?
- 1060 Views
Last post by fiore67
- 721 Views
Last post by MoVolvos
- 686 Views
Last post by RickHaleParker
- 13 Replies
- 3952 Views
Last post by MrAl
- 13 Replies
- 3644 Views
Last post by jerseykat1
