my car is a 2005 xc70- 120k and
got this message when I start it this morning
Car runs ok -no problems Battery is new and shows 12.6 with engine off in the morning overnight rest
I get 13.5 V when running w/no load voltage stays steady but under load(ac/fog lights/heater/lights) drops to 12.8.if I turn off all electrical load the voltage reading come back to 13.5.
If I let the car run 15 min after the engine is off the battery reads 12.8, meaning the alternator is charging and is working.I am not sure if it has a smart regulator or not-I assume it does since the default 13.5v charge.
My alternator has an exterior plastic box attached to alternator and if I search for Voltage regulator part it shows me that part as a separate part for under $50
Maybe i can just replace that instead the alternator that looks ok
I assume since the battery and alternator is ok the only part left is the voltage regulator defective
I am right-please correct me if wrong?
power System Service urgent message
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
In theory 2005 has the smart regulator
The regulator may be good at 13.5 if the battery is fully charged (for a smart one) but 12.8V is weak - is that when the message pops up?
When you discharge a bit the battery then start the car, does the regulator show near 14.4V?
What happened with the old battery, was it weak?
12.8V 15 minutes after shutting the engine is excellent, but not sure why does it drop to 12.6V the next morning (assuming all lights are off including trunk lights, when measuring). From 12.8 to 12.6 it means the battery has lost some 10% of it's charge.
May well indicate a parasitic drain. Under the trunk lid cover, try disconnecting the rear plate lights connector see if the battery has a better charge in the morning.
adrian22
- Year and Model: s60 2006
thanks for reply
I am answering to your questions
12.6v BATTERY IS OK -FOR A FULL CHARGED ONE------
----the VOLTAGE WITH ENGINE ON SHOULD BE 14.2 NOT 13.5 ---THAT IS CONSISTENT DEFAULT CHARGE if the regulator is dead ------------Dropping to 12.8 IS UNDER MAX electrical LOAD-AND COMING BACK TO 13.5 IF LOAD REMOVED and stay consistent
----NO -THIS IS THE PROBLEM-AS SOON I START THE CAR (maybe 15 sec after ) I GOT THE POWER SYSTEM + BATTERY LOGO
MESSAGE
What happened with the old battery, was it weak? -IT WAS 5 YEAR OLD AND VERY WEEK that was replaced 1 year ago
MESSAGE
adrian22
- 2350 Views
Last post by jimmy57
- 2637 Views
Last post by ggleavitt
- 1765 Views
- 17857 Views
Last post by kranz
- 3068 Views
Last post by RickHaleParker
