I have been searching and I can not find a clear answer to this, so any help would be really appreciated.
I have a 2007 XC 90 3.2 FWD with the following problem. The last 2 days I have had the following problem.
Twice I received the message " Power System Service Urgent" battery light comes on also, along with a high pitched squeal for a minute or two.
I stop and it goes away but it came on again today.
Is a pulley or belt on the alternator bad?
Thanks,
Joey
07 XC90 3.2 Sporadic Message Power System Service Urgent Loud Squeal
VolvoS402006
- Year and Model: 2006 Volvo S40
Reason: Edited title. Please, no "ALL CAPS"s in titles.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
the drive side is slipping or the driven side on alt with the one way clutch is faulty. The intake is easy. Down low are a couple of bolts and the ones at top are readily accessible. The intake only needs to be set aside. The pulley should freewheel one way and drive alternator the other. I see them bind both ways when I've heard them squeal in most cases. In any case, the drive side needs to be inspected and tightened. You need to use large slip joint pliers and a cloth to protect the drive gear while breaking it loose and when tightening. Use a drop of Loc-tite green (best) or red and apply inside the area it fits on shaft. If you remove bolt and the gear will not come off then bolt back and tighten to 35 ft-lbs. you only need to loc-tite it if it will come off.
- 9939 Views
Last post by adrian22
- 2624 Views
Last post by ggleavitt
- 1762 Views
Last post by jimmy57
- 17853 Views
Last post by kranz
- 3066 Views
Last post by RickHaleParker
