Hi all, I finally had enough issues to take apart the D pillar to sort out wire damage caused by the L tailgate hinge. So I got everything apart and the culprit(s) pretty much jumped out at me. I got the butt connectors on and 2 out of 3 issues are gone.
1. How did y'all put it back? I really don't want to rig bag up with a zip tie to that little clip, maybe a tad looser?
2. Where have all the wiring diagrams gone? I know they are not posted publicly anymore, but are there any others devoted to the XC wagon? My remedy fixed my rear demister, rear wiper rest position, but it did not fix the tailgate open light on my dash.....I suppose I will need to replace the latch mechanism.
Famous wagon tailgate wire question
- Year and Model: Many Volvos
- Been thanked: 76 times
I usually splice in an extra chunk of wire but then again I use solder and heat shrink so that the splices don't get too big around. With the little bit of extra wire the harness can be routed in a little bit more relaxed position but over enough time it will break again.
The schematics can be found here:
http://www.volvowiringdiagrams.com/
There are mostly complete but it is a struggle to find things since the pages didn't get scanned in order.
- Has thanked: 317 times
- Been thanked: 531 times
I just taped everything back up after hacking up the covering. The clip on my car broke, so it still moves. I would try to loosely tie everything back up a little bit.
My license plate lights still don't work all the time, and my rear wiper stops in random positions. Whatever I've done in there has only made things worse...
DrJammer
- Year and Model: 2000 V70XC - 195k
- Has thanked: 1 time
Thanks folks. I could not make it much longer without rear demister.
rear wiper was the 1st hint I got, it would stop wherever I turned it off and I would try and time it so I'd hit the switch at the rest side.
rear demist as the colder weather comes is a necessity.
I will be trying the double zip tie action since I have a good feeling I'll be back in here at some point.
one last point, I undid the trim piece covering the top rear hatch light area before slowly unsnapping the top side trim, it gave a bit more wiggle room for removal. remove the light and the 2 circles caps/torx
Ex-Volvos
2004 v70 N/A - traded in at 75k
2008 S60 - leased
1998 S70 T5 - might still have her if I knew about this forum when I owned it
2008 S60 - leased
- Has thanked: 1611 times
- Been thanked: 4075 times
Liquid tape product in this thread, might be good stuff to try on this job
https://www.matthewsvolvosite.com/forums ... =1&t=26393
- 3251 Views
Last post by Lurch
- 12 Replies
- 6737 Views
Last post by mrbrian200
- 2702 Views
- 845 Views
Last post by clickraider
- 890 Views
Last post by Sommerfeldt
