Rear intake seal?
Syd_c70
Year and Model: C70 2002
Rear intake seal?
Post by Syd_c70 »
Hi folks
Can you please take a look at this picture and tell me if there is such a seal in the rear intake of my Volvo C70 2002 turbo? If there is, do I have to use the Volvo tool 9995919 to pry it out like the rear exhaust end?
I am in the process of replacing front and rear intake and exhaust seals because of leaking oil. There was some oil when I removed the cap cover of the rear intake so not sure if there is a seal there.
TIA.
rear intake2.jpg (50.87 KiB) Viewed 836 times
bskeels
Year and Model: 1997 Volvo 960
Been thanked: 3 times
Post by bskeels »
The cover that you pried out is the seal, if you did any damage to the cover you should replace it. 1397381
The Fleet
2012 Ram 2500
97 Volvo 960
98 V70 AWD (208000+)
66 Volvo 122s sedan project
98 Volvo V70 XC (151,000+) parts car
08 Volvo V50 T5
"Human history becomes more and more a race between education and catastrophe" - H. G. Wells
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
I added a standard seal to mine that goes behind the cover plate. The seal is the same as the exhaust seal. Getting the cover plate off without damaging it is nearly impossible and I don't trust the setup.
Syd_c70
Post by Syd_c70 »
Thanks bskeels and Lee.....Yeah, I've added the the same seal in there as well. Just started the car and seems to be fine. Idle is the same as before and rev as normal so just need a test drive.
No way to get the cover cap off without damaging it. This is the reason why they make the center out of rubber I think. Anyhow, got the replacement cap on hand as I know I will damage it during the removal process.
