I have a 98 S70 T5 that I picked up a couple years ago. When I bought it the previous owner had installed an open air intake. I have an old airbox from a 1994 2.4 n/a 850. I was wondering if I could use that airbox for the bottom piece and pick up just the cover from a junkyard since my S70 has the air pump line going to the airbox as well.
Thanks
n/a vs turbo airbox
shaker_chi
- Year and Model: 94 850, 98 S70T5 M
- Has thanked: 3 times
- Been thanked: 3 times
- Has thanked: 316 times
- Been thanked: 531 times
I think the bottom half will work, but you will definitely need a turbo top half, just because of the different outlet.
- Clemens
- Has thanked: 498 times
- Been thanked: 228 times
And because of the TURBO lettering ...
1996 855 R,
2010 V70 D5,
2010 V70 D5,
Clemens wrote:And because of the TURBO lettering ...
- Has thanked: 311 times
- Been thanked: 817 times
The bottom halves are slightly different: the NA piece will have a flap thermostat. You will want to gut that, remove the door completely so it does not interfere with intake. I would just spend the extra few bucks and get a whole turbo box, sounds like you do have access to a junkyard.
And seize this opportunity to get rid of the air pump!
- 2526 Views
Last post by erikv11
- 2127 Views
- 21 Replies
- 11052 Views
- 3376 Views
Last post by jonesg
- 1156 Views
Last post by admasters71
