V70 Mk2 2006 2.4D
I have a weird issue, when turning on my ignition, the oil warning lamp does not come on. I'm sure it used to, but has anyone else got this issue? Volvo near where I live are no good on their advice at all.
might it be I have a faulty oil pressure switch?
any advice is good thanks.
Dashboard Oil Lamp not Illuminating
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Did you just bought the car? Good chances PO had removed or taped the oil led inside the DIM. Surely for a good reason.
Btw, disconnect the battery any moment the DIM is disconnected.
whiteskies
- Year and Model: V70 2006
I've had the car for just over 2 years and have covered 40k miles. I have removed the dashboard in the past as the volvo dealer said it could be a lamp blown on the dash, but these are all surface mounted LED's. I'm just concerned if one day I loose oil pressure that the system won't tell me. The local volver dealer to me is next to useless!
- oragex
These surface mount leds just don't just burn like that. Most possible and already seen on forum here, is previous owner has placed a small piece of tape over the led. If you remove the dash (also called DIM), the car battery must be disconnected any time the DIM is unplugged.
you may also have a look at this forum of your area, http://volvoforums.org.uk/
- 1301 Views
Last post by SmirnouF
- 6841 Views
Last post by Rokas13
- 20 Replies
- 8810 Views
Last post by Rattnalle
- 1582 Views
Last post by Py
- 3177 Views
Last post by Georgeandkira
