volvo s80 2000 surges Topic is solved
matts80
Year and Model: 2000 s80 t6 2.8
Post by matts80 »
hi i have a 2000 volvo s80 t6 2.8 i got it 3 months after the the previous owner have a new engine installed i have done about 8000 km in it ,3 months after it started to rev back and forth from 1700 rpm at 80 kmh then back to 1500 rpm. then at a 100 kmh it would rev back and forth from 2000 rpm to 2300 rpm worst if i'm going up a hill.also has the check engine light on it idles fine can hardly feel it /hear it running . if i let my foot off lightly or put my foot down it would go away i took the maf sensor off and cleaned it went fine for 50 km then went back to doing it again. i also had the car running and disconnected the maf sensor and the car cut out as expected not sure what it could be but it is p@#%ing me off big time does anybody have any ideas
Volvo S80
Year and Model: 1999
Has thanked: 7 times
Been thanked: 2 times
Post by Volvo S80 »
Hi Matt,
Try cleaning the throttle body and see if it helps.
matts80
Post by matts80 »
thanks I have a new throttle body sensor coming ,will clean throttle body then .Will post the outcome cheers
matts80
Post by matts80 »
finally took off the etm, it turn out to be the sensor strip inside.it had no scratches but it was faded and could see though it, i fitted a after market contactless sensor it removed the problem, along with the engine light i followed a youtube video on how to do bit of a mission but it was pretty straight forward here is the link
