Still struggling to get the 93 850 started for those who might have read my post.
Today was more hopeful, with a few encouraging pops before the battery died; it was low anyway.
I swapped in a fuel pump I've had laying around for a few years. I'm getting power to pump which hums when the key is turned on.
About the question: I think I remember a discussion about rebuilding a fuel pump with a kit but don't recall if anybody had done it successfully. If you have knowledge of this, please share.
The ECT. After reading cn90's post listing a range of resistance values for the coolant temp sensor, I measured mine. Ambient temp was in high 30's today and of course engine hadn't been running.
The ohm reading I got on my analog meter was around 3900. It should be around 6k according to cn90's table, also verified online.
Is that enough of a difference to prevent a cold start?
Re: brand. The SWF coolant temp sensor is available locally for around $60.00.
The FAE brand can be had for less than $20.00. But is the FAE trustworthy?
850's new FP or rebuild? FAE ECT?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Everything except Oem Volvo(swf which is Valeo btw),or at least Vernet is a waste of time.
Nothing else will work on these cars.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- kranz
- Year and Model: '98 V70 NA stick
- Been thanked: 8 times
Not a Volvo, but I rebuilt a fuel pump for a different Swedish car. I replaced the failed OEM Walbro electric fuel pump with another Walbro and had no problems with it. It came with a replacement rubber mounting donut. It came with instructions, was not a difficult repair, and was much cheaper than purchase of the whole fuel pump assembly. During the process I learned that gasoline is not a good electrical conductor.JimBee wrote: I swapped in a fuel pump I've had laying around for a few years. I'm getting power to pump which hums when the key is turned on.
Les is more.
FAE may be a roll of the dice. If it works out of the box now, it might fail in short time; at a time with less convenience to replace.
Fumes from gasoline makes a great conductor...kranz wrote:During the process I learned that gasoline is not a good electrical conductor.
ugh smh 850 Turbo fridge
- misha
Walbro was NEVER OEM for Volvo.kranz wrote:... I replaced the failed OEM Walbro electric fuel pump with another Walbro and had no problems with it...
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- kranz
Don't know about the conductive properties of gasoline fumes, but they are easily combustible. They would require a spark to get going.beigg wrote:Fumes from gasoline makes a great conductor...
Les is more.
- kranz
Walbro WAS OEM for the other Swedish manufacturer's product that I mentioned I was repairing. From my experience they made a good product, and if they make a replacement for VOLVo pumps, it might make a suitable replacement.misha wrote:[quote="kranzWalbro was NEVER OEM for Volvo.
Les is more.
- misha
Volvo oem fuel pumps are made by Bosch.
Replacements can be from Bosch,Hella,Walbro,Pierburg,Siemens....whole assembly or just an insert.
Walbro is making performance fuel pumps too and have a good reputation as long as it's not a cheap chineese copy.
You don't need to replace the whole assembly....just the insert and oem Bosch is also available from Volvo.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
