Fuel Pressure Sensor
PatX
Year and Model: Volvo XC90
Post by PatX »
2008 XC90 V8 4.4L
I pulled a P0089 and P0192 Codes.
Car runs smooth. No misfire. At Idle and increased RPM's.
The Fuel Pressure runs at 55#'s.
Bring up RPM's- Rise in Pressure.
Fuel Trims seem normal - Short stayed within normal positive range at idle. Then went into negatives upon higher RPM's. Long Trim followed.
No fuel at Regulator Vacuum hose.
Assumed no vacuum leaks . Or bad Pressure Regulator.
Oxygen Sensors all operated in normal ranges- .45MV Closed loop
"My" diagnose(best guess) is, Fuel Pressure Sensor bad.
Am I correct ?
To replace- Hands to big to fit under intake manifold. Are there any other options ?
Thank you
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
Can you measure the fuel pressure independently?
I know that with VIDA plugged in, I can see what my fuel pressure is. On my 850 and S80 there's a fitting on the fuel rail where I can connect a gauge. (I would think there would be a similar one on the V8, but I haven't had to measure that yet, so I don't know for certain.)
So, even just in the garage, one could connect a gauge, even mechanical, and validate whether the fuel pressure sensor is or is not giving reasonably valid readings.
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
PatX
Post by PatX »
I measured the fuel pressure. There is a Schrader valve off the fuel rail.
I was inquiring whether I was neglecting to test anything else, that my scanner would
not indicate, that it is "not" the Fuel Pressure Sensor ?
Also, if there were an alternate way of replacing the sensor, without pulling the intake manifold off ?
