I see lot's of people has almost a same problem with that ecc unit. My 94 850 turbo has a same problem. Everything is ok when dial knobs are set in manual mode, but when I turn to aut., doesn't work. But here is the funniest part. As I said doesen't work, yes it's true, but when I turn my engine off and turn my ignition on after, it's working ia auto mode, but If I start my engine, fans stop blowing, and both indicator flashing for 10-15 sec. No faulty codes shown on obd reader. Does anybody know something about. Thank for any answer, Des
Electronic climate control
Another question!
- phils94850
- Year and Model: 2009 s60 turbo
Des.... from what ive read most people recommend replacing the blower resistor first. this goes out often on our cars and causes all kinds of problems. Mine is bad right now i need to replace it....
1996 Platinum Edition
tasatterly
- Year and Model:
Think I have same problem, can you tell me if you were able to fix? The climate control does not work in auto with car running, the fan works in manual mode fine. When engine is off and ignition on, then the climate control works in auto.
Did you find a problem with the resistor as mentioned above?
thanks,
thanks,
- 11 Replies
- 6843 Views
Last post by maxi948
- 3499 Views
Last post by caliwagon
- 701 Views
Last post by Top Notch
- 1456 Views
Last post by jreed
- 1726 Views
Last post by mydamnvolvo
