Possible to inspect a/c evaporator while replacing heater core?
DanSC
Year and Model: 2001 S80 2.9
Post by DanSC »
Hello,
I have a heater core leak, as well as inoperative air conditioning on my 2001 S80 2.9. I'm guessing the issues aren't related, but is it possible to inspect the a/c evaporator with the heater core removed? Perhaps with a borescope? I do plan to inspect the evaporator drain per this guide.
Also, here is what diagnostics I have done on my a/c, in case anyone has advice.
  • The compressor clutch will activate when jumping relay in fuse panel
  • I used one of the low-side fill kits (I know this isn't ideal) to inject R134a with UV dye. Compressor engaged, and I let it run.
  • A consistent hissing sound comes from within the dash with a/c running; this makes me think evaporator or expansion valve leak. Maybe it's just a result of low refrigerant?
  • Compressor eventually wouldn't engage; presumably enough coolant leaked out. When I re-attached the low-side A/C coolant again, the gauge still shows pressure when the a/c switch is off.
  • This part leaves me confused. Now when I turn on the a/c switch, the low-side pressure drops to zero, even though the compressor is not spinning. It's also not taking any refrigerant, judged by weighing the can.
  • I haven't found any leaks under the hood, but I haven't removed the bumper cover to inspect the dryer & condenser.
  • I do plan on getting a real manifold gauge set and vacuum pump.
DanSC
Post by DanSC »
An update: You can see a portion of the evaporator with the heater core removed, but not nearly enough for a full inspection.
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
I think the compressor is running but you can't see it. Mark the ac clutch hub with a crayon or other and try that again. The a/c pressure will not change like that if the compressor is not running.
