Has anyone had this problem?...
XC70 fuel pump is leaking from the top of the yellow housing where there is a round piece with a cross in the middle. Looks like it's where the fuel return connects.
Please see photo attached...
Wondering if anyone has a fix that doesn't involve replacing the whole pump?
Xc70 fuel pump leaking from housing
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
If I remember well, this was a recall in hot areas and yours seems to be one of them. I think someone also tried some super glue, it may or not work. it's better to just replace the pump if Volvo doesn't want to pay for it
precopster
- Year and Model: Lots
- Been thanked: 128 times
As above that JB Weld will button it up nicely.
- Been thanked: 504 times
I personally don't mess with JB Weld in this area b/c of safety issue.
The recall info is below:
http://www.autoblog.com/2009/12/22/volv ... over-fuel/
Check local Volvo dealer for recall info in Australia...
phrm96
- Year and Model: V70 2004
I had the same experience, coincidentally right after I did the PCV breather system. Presumed it was a leak from an injector or the main fuel line.
Cleaned out the dirt and gunk, sanded the plastic area with 100 grit on the end of a small flathead screwdriver. JB Welded, 24 hr cure. No leaks or smells. Fingers crossed.
- 1430 Views
Last post by jonesg
- 1337 Views
Last post by Krons
- 6289 Views
Last post by DavidE7
- 42 Replies
- 12173 Views
Last post by Maestrours
- 5122 Views
Last post by wizechatmgr
