2006 S80: any issues
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
Year and Model: 2004 V70 2.5T
Been thanked: 472 times
Post by cn90 »
Hi guys,
I currently own 2 Volvos and very familiar with these 2 cars repair issues etc.:
- 1998 S70 GLT 2.5T with 185K miles
- 2005 XC90 AWD 2.5T with 105K miles
* I am looking at a 2006 S80 with 80K miles and wonder if the trans is the same as in the XC90, i.e., is it made by Aisin?
* Any transmission issues?
* Any issues with this particular year of 2006?
Legofan
Year and Model: 2001 S80 T6
Post by Legofan »
Transmission
6-speed Volvo M66 manual
6-speed Aisin TF-80SC automatic
8-speed Aisin TG-81SC automatic[21]
2001 S80 T6 Moondust sent to auction for scrap
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
Didn't the P2-P3 changeover happen midyear '06? Or are the P3s strictly MY07+?
An Early MY06 might have the AW55-50/51SN tranny as opposed to the TF series Y/N?
Legofan
Post by Legofan »
mrbrian200 wrote: 16 May 2017, 12:53 Didn't the P2-P3 changeover happen midyear '06? Or are the P3s strictly MY07+?
As far as I can tell, sales started June 06 so it is possible to get a P2 MY06
mrbrian200
In either case they're both considered solid trannys yes or no? The AWs are good so long as you're not subjecting them to constant daily abuse or put the wrong fluid in them.
quietlymknnoise67
Year and Model: 2003 C70
Post by quietlymknnoise67 »
My 06 S80 has the 2.5T with the AN55-50SN has been a very solid ride. Got it with 35k and now has 149k with only typical maintenance. ie. timing belt, control arms bushings and brakes.
Legofan
Post by Legofan »
mrbrian200 wrote: 18 May 2017, 15:00 In either case they're both considered solid trannys yes or no? The AWs are good so long as you're not subjecting them to constant daily abuse or put the wrong fluid in them.
As far as I seen and been told the MY06 solved many transmission issues by discontinuing the 4T65EGT. The M66 is highly sought after and I've read a few M66 swaps into cars with AWs. I'd say the MY06 S80s are pretty solid but, they are the first year P3 so take that into consideration.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
If the S80 is a 6 cylinder 2006 MY then that year would have the GM transmission. 5 cylinder is as described above with the Aisin transmission.
2007 is the first year for the 2nd generation S80 that uses 6 speed Aisin gearbox and the new 3.2 non turbo 6 cylinder. Turbo 3.0 litre in the 2nd gen showed up the second year (2008).
