So I just replaced the driver's side rear axle on my 2002 XC70. Wow - what a royal pain in the butt!
In retrospect, were I to do it again (which I most definitely will not) I would probably do both sides, accept the fact that I'm going to have to completely disassemble the entire rear suspension system, and drop the differential.
For what it's worth, I ordered the axle from PartsGeek (USA Industries AX-1155) for a little over $100. I fully realize it's not OEM, and won't run 400,000 miles, but on a car with over 230,000 miles, I don't plan to run it forever.
To sum up: This job is not for the faint of heart!
Rear Axle Replacement on '02 XC70
JeffHicks
- Year and Model: 1989 240 Wagon,
That could be. But I'm not going to pay over $600 for an OEM axle, to put under a car that my wife drives 1/2 mile each way to work each day. We put about 2,500 miles per year on this car, so I don't think the off-brand axle is going to be its demise.vtl wrote: 26 May 2017, 17:15 You may very likely have 230k miles original axle run smoother than USA Industries in just 20k miles.
1989 240 Wagon, 1999 V70 Base, 2002 XC70, 2005 V70 T5
- Been thanked: 4064 times
That's the right call Jeff. That's brutal miles on a car by the way. Try to blow it up to 55 for even just 20 minutes each weekend
JeffHicks
There was no 55 mph before I replaced that rear axle!abscate wrote: 27 May 2017, 04:26 That's the right call Jeff. That's brutal miles on a car by the way. Try to blow it up to 55 for even just 20 minutes each weekend
- 750 Views
Last post by JeffHicks
- 606 Views
Last post by Blacklab467
- 1280 Views
Last post by precopster
- 1401 Views
Last post by ryanmcgrim
- 1448 Views
Last post by BlackBart
