After an OBD reading on my '96 850 Turbo, I received the error code P 755 which stated the transmission solenoid B was malfunctioning. Has anyone experienced this problem? Is the solenoid inside or outside the tranny? Does it need to be replaced or simply flush the tranny? I'd appreciate any help.
vvonc
Transmission Solenoid B - Error Code 755
- Has thanked: 17 times
- Been thanked: 35 times
Don't know much about that particular solenoid, but I did find this:
http://www.volvospeed.com/vs_forum/lofi ... 38355.html
- Tsquared
- Year and Model: 11 C30
- Has thanked: 1 time
The solenoid is on the inside of the transmission. Flushing may wash some grit out that may be the cause of the malfunction - it also may do nothing.
I had the same issues with my 96 about 3 years ago. I ended up replacing the trans with a new one (it was within $200 of a rebuild if memory serves me).
Good Luck,
T
Good Luck,
T
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
Have you called anyone to see what the code is for specifically? I had a trans code early in the year that was for the torque converter solenoid, after having the dreaded flashing arrow come on with no symptoms (I was hoping it was the shift switch). This solenoid was located inside the trans, so it had to be removed to replace the solenoid. My mechanic couldn't do it, sent me to dealership. Ended up having another indy Volvo shop do it and haven't had any problems since. Cost was $750 total.
BTW, called the dealership and said they would charge the same, so apparently price was standard (mainly labor). It may not be a bad idea in this situation to try the dealership.
Anthony
'98 S70
'98 S70
- 321 Views
Last post by coalvatis
- 8408 Views
Last post by RickHaleParker
- 3336 Views
Last post by RichCrewe
- 12 Replies
- 5141 Views
Last post by mrbrian200
- 23 Replies
- 10276 Views
