Hi. I've been having a check engine message popping up. My OBII reader says it is fault code P0347 which appears to be a camshaft sensor low signal error. I replaced the sensor with a new one, but I am consistently getting the P0347 code. The car seems to be running fine and I have had no problems starting the car lately.
I have had some other codes related to the transmission, but it is working fine. I flushed it a couple of years ago (like 6 times) and haven't had any issues afterwards.
I also recently replaced the alarm siren module with a new one. I don't remember the code being there before that, but it may have been. I had replaced the alarm module because it's battery was draining the cars main battery and causing it not to start.
I've also recently replaced the battery, which I did before I realized the problem was with the alarm module. I'm wondering if it could possibly be a power issue, hence the "low signal" message.
If anyone has any ideas, I could sure use them. I'm at my wits end.
Oh. My vehicle is a 2002 Volvo S80.
Camshaft Sensor Low Signal P0347
I've since replaced the battery with the one I previously had in the car, and I'm still getting this P0347 code. So frustrating. If anyone has any insight, I'd really appreciate it.
I had replaced the camshaft sensor and the code didn't away. Is there something in line, or attached to the actual sensor that I could try?
- 401 Views
Last post by Dharp
- 8905 Views
Last post by rhubarb
- 4092 Views
Last post by RickHaleParker
- 232 Views
Last post by perhss70
- 2506 Views
Last post by Volvo Kush
