-99 S70 what Gearbox fluid?
- Has thanked: 317 times
- Been thanked: 531 times
It seems 31280771 is the current part number.
- theWIFES_S70
- Has thanked: 61 times
- Been thanked: 37 times
I believe you can use one of these:
viewtopic.php?t=72329
Also, see here:
https://volvoforums.com/forum/volvo-s70 ... 3-a-16896/
Are you sure you don't have shifter bushings that are completely shot? I'd get in there and replace them, too. Gear oils last a long time.
Retired:
2015 Volvo S60, T5, 85K
- theWIFES_S70
I am almost certain you have to put a GL4 spec fluid in there. Double-check. I think you're supposed to put this in there... But again, double check!
https://www.fcpeuro.com/products/mtl-75 ... r-31280771
Here are two overviews of shifter bushing placement, etc. There's rubber that cracks and contributes to slop in your shifts.
It's a great little upgrade. I am using aluminum shifter bushings I purchased off eBay for around $10.
RobertDIY used some bearings which are probably much better!
Retired:
If you're feeling adventurous... http://www.snabb.us/Delrin-Shifter-Asse ... _p_27.html
Delrin bushings in general are expensive... $170 for the subframe bushings I want.knalla1 wrote: 28 Jun 2017, 11:26That price is just ridiculous. If only I had a 3D printer.bmdubya1198 wrote: 28 Jun 2017, 10:52 If you're feeling adventurous... http://www.snabb.us/Delrin-Shifter-Asse ... _p_27.html![]()
- 11 Replies
- 6645 Views
Last post by kaneelschep
- 370 Views
- 29 Replies
- 5674 Views
Last post by Gouws
- 3133 Views
Last post by Gouws
- 752 Views
Last post by Gouws
