Throttle Body , Remanufactured It's replace, this ETS , P1041 I don't have any description that the P1041 mean , Run rough when the temperatury are changed.
Can somebody know what can be the problem .
David
ETS , Light it's On with Engine code P1041
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
P1041 is a problem with #1 injector or #1 injector harness. If you have a noid light, it may assist. There is also a reference to the ECM but that isn't very likely.
If it were me, I'd unplug #1 injector while running and see if I notice a difference. If there is no difference you know where to start...
http://www.micro-tronik.com/faultcodes/ ... code_p1041
- wizechatmgr
As far as the ETS goes, have someone with a vida/dice run it through the Throttle body test to make sure it is fully within spec. and then clear the code. I was unable to remove that code with a regular "consumer" code reader. Some may be able, but the two I had were unable. My code was triggered by pulling the wrong fuse while running...
When you do this test it takes the reference of both potentiometers and compares them to their "theoretical" reference point of where the throttle should be at that point in time while slowly going from full open to full closed, rinse and repeat. I believe it allows something like +/- 10% but I haven't looked at that in a while. It gives a nice graph of both readings, the position, and the unwanted deviation.
Dimi2233
- Year and Model: 1999 V70
memberlist.php?mode=viewprofile&u=93269
Thanks , It's not short on #1 Injector harness , I disconnected the Injector harness , I bent injector contact for better contacts , work better , Until code P1041 show up.
I don't have noid light.
I appreciate your help.
David
David
- 4165 Views
Last post by Martyans
- 746 Views
- 1250 Views
- 3120 Views
Last post by itsmekirby
- 120 Views
Last post by Oro
