2004 V70 OBD II codes...
arbop
Year and Model: 2004 V70
Post by arbop »
Recently bought a very nice 2004 V70. Just started throwing a code, P2187. I looked it up, "adaptive heated oxygen sensor...", but would anyone be able to tell me what I should check/change first? Perhaps O2 sensor, but which one?
Thanks
Current: 2004 V70
Prev: 73 1800ES, 76 240DL, 79 245 manual, 78 242GT, 81 245 GLT, 87 745 Turbo, 97 850 T-5, 89 745 manual wagon, 1992 240, (this one saved my life!). 2004 V70 2.5T. Whew!
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
No expert on O2 sensors but I believe the front sensor is the heated one, its heated to reduce warm up time for the adaptive trims to kick in or something like that.
I would try to get the proper volvo vida codes, they show a bit more than the OBD code reader.
Mine said O2 sensor signal missing, it was the fuse.
In the engine bay fuse box, fuse #4 is for the O2 sensors.
jonesg
Post by jonesg »
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 89 times
Post by chrism »
Some people are mentioning a cracked oil separator box or upper PCV hose leak:
http://forums.swedespeed.com/showthread.php?120605
http://www.volvo-forums.com/t32290-chec ... -p2187.htm
jonesg
Post by jonesg »
chrism wrote: 21 Aug 2017, 14:04 Some people are mentioning a cracked oil separator box or upper PCV hose leak:
Can be caused by vac leak anywhere in the system, that causes the front O2 to signal for richer mix.
I've got a leaking injector O ring seal doing the same thing, have to get to it before winter.
It makes sense to check the sensors, if good then the problem is upstream.
This can be done with a laser thermometer or multimeter.
Lots of youtube videos for this.
Has thanked: 1610 times
Been thanked: 4065 times
That code descriptor is not right. You need to get the Volvo code read bY VIDA and report back
