Good evening!
The error burns constantly, from start plus motor system wart. erforderl. (Engine system service required)
When connected to the Vida, the ECM-6200 error is displayed. The cooling fan fan control module is a faulty signal.
The fan operates normally, in the Vida on the "Fan activation" tab, the module operates at three levels.
When the climate was activated, it worked. The fan is turned on at 105 degrees.
After the terminal is disconnected from the battery, it disappears for 15 minutes.
Interested in the reason?
Thank You in Advance
(using translate.google)
ECM-6200 Engine cooling fan control module. Faulty sign.
- 2490 Views
- 3850 Views
Last post by PixelDust
- 5234 Views
- 509 Views
Last post by lukask
- 207 Views
Last post by UgDriveCar
