Swapping Shifter Knobs from an '02 to an '08
PB0208
Year and Model: 2008 S80
Post by PB0208 »
Hi everyone. First time poster, long time lurker. Thank you for your input. I recently had to take my 2002 S80 2.9L non-turbo off the road after 211,000 miles. I had that car since I was 16, and needless to say made a lot of good memories with it. Yesterday I acquired a 2008 S80 3.2L non-turbo. I would like to incorporate a piece of the old car in with the new. I watched some videos on removing the shift knob and it seems straightforward. I've also seen some posts, including one from an individual who swapped his 2008 model knob for a newer one from 2013, so I know that can be done. But my question is as follows: It possible to take an old knob from a 2002 and put it on a newer 2008 model? If not, I'll also take suggestions for other parts that could easily be swapped. Again thank you.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
You'll need to pull both knobs with their rod and compare. The rod has some grease on it which is important for easy changing gears. If there is a leather boot around the knob, it usually just slides off by gently prying with a butter knife.
gnalan
Year and Model: 2001 S60
Has thanked: 557 times
Been thanked: 135 times
Post by gnalan »
Wheels and tires, maybe? Then keep the newer ones as backup?
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Looks like they changed the Shifter Knob in 2005. The only way to know for sure is to try.
Active
Past
