Inner tie rod id 98 v70
- skloon
- Year and Model: 94 850 95 850 04 S60
- Been thanked: 2 times
On my wife's V70 I suspect that the inner tie rods may be bad- the boots are torn, the issue is the rack came from another car a few years back so I don't know which one it is, is there a way to tell if it is a 4 or 5 ?
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
on the underside of the rack (where the pinion gear is) you will see a rectangular or round plate. I'll edit this after I go look at my spare TRW.
http://forums.swedespeed.com/showthread ... ost1342059
There's a picture in here that shows where to look for markings, either "France" (SMI) or "TRW"
Current Volvos:
- FLXC90
From another (OLD) post on another forum, ABS guru Matty Moo says "Below is an SMI inner tie-rod, and it's notched for a wrench. A TRW inner is round without being set up for a wrench." So if your boots are loose you could check there as well.FLXC90 wrote: 05 Jan 2018, 17:25 on the underside of the rack (where the pinion gear is) you will see a rectangular or round plate. I'll edit this after I go look at my spare TRW.
Current Volvos:
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Torn boots on inner tie rods doesn't neccessarily mean that they are bad.
If they are bad they would have play in them and would make knocking noise just like outer ones.
Visual inspection will tell you nothing.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Misho is correct, I had the same issue.
I used a syringe to insert some grease in the bellows, then I sealed it with silicon. It's been fine every since, as long as you catch it early.
It's just a dust boot that sees very little movement.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- FLXC90
Sorry, was late night trolling and missed that it is just boot. see viewtopic.php?f=1&t=83982 for symptoms (severe) of worn tie-rod
Current Volvos:
- 2688 Views
Last post by manovlov
- 1229 Views
Last post by EstVolvo
- 1241 Views
Last post by mika
- 1560 Views
Last post by prwood
- 924 Views
Last post by precopster
